mrfoo
- Gadsden, Alabama
I have a 98 4.0 and I went to change the oil since I had a few minutes of free time and my freakin oil cap screwed off from the part that is threaded with the engine block. It appears the gears chewed themselves up. Anyway I am going to get one from a junkyard tommorow but just wanted to know if there is anything special I should do to take it off the remaining part on the engine. It is not badly damaged, I will just try to use pliers to take it off. Thanks in advance.
Daniel
Daniel
