El Sheetbox
Re: El Junky
Tell me about it! Can't wait to get home and look at this Dana 60 rear my buddy has...
Re: El Junky
Damn it's a Dana 61 :(
Up big johnson
Re: El Junky
dude get a SRW 14 bolt and swap dually hubs and get some cheap 8 lug rims from summit and call it good. shave it and go discs , keep the 4.10s and weld it and call it done.
rehear the front to 4.10 at that point.
Re: El Junky
So is it even worth the time to swap a 30 spline dana 60 into the rear?
30-spline 60 shafts are the same size as the 44 shafts you are breaking now. Full-floating is better however. If it were me, I'd do it once and go to 35-spline chromos. Bore the spindles or find a better 60.
Re: El Junky
14 bolt is full floating. 3rd pinion bearing.
"14 bolt shafts are 30 spline but are cut differently than most other axles. They are ~1.625" and are most comperable to 37 spline dana axles. They do neck down but the way they do may be the genius in their design: having some give before simply snapping."
http://www.colorado4x4.org/vbb/showthread.php?177684-14-bolt-vs-D70
I guess you could regear the 14bolt to 3.55 if you really want to keep the 30? you might be the first wheeler in history to want to actually gear a 14 bolt to 3.55 for rock crawling instead of 5.XXX something.
or if you are only breaking shafts grab some chromos for the rear from a NAXJA vendor and see how long they last.
Re: El Junky
My rear 44 had 30spl chromos...it was fairly inexpensive if I remember correctly, like $250?
Re: El Junky
did you talk to rwkhaus dude?
Re: El Junky
oh wow. well shit 259 is a killer deal then. also remember you will need new bearings and seals.
Re: El Junky
Do it, see if you can break them:)
Re: El Junky
go for it! thats the way to go.
