- Mission Viejo
Easy guys, Jes just got his first XJ. He's needing that body lift for his 42s on D30 and D35 because those 42s rub
oops I mean D60
oops I mean D60
I've heard that shackle angles are tough to get right when using coilovers. I suppose you could use a drop spindle to offset the angle enough to get good travel, and if you used terraflex revolver shackles the angles are supposibly not even a concern, but I've never seen it in person. The harder part is trying to find the correct drop spindle for a dana 35.
How many horse powers do you gain with a body lift. :dunce:
1 Clydesdale
Make sure you order the Polly Your Ethane body lift
How much body lift before I need an SYE?
The great thing about the body lift is that you never need an sye with it
now, does that cause death wobble in the rear?Yes, but you might get some bumpsteer from the rear axle with anything above 3" on body lift.
How many horse powers do you gain with a body lift? :dunce: Will my stock ds work on a 97+ with a 6" body lift without vibes, or do I need an SYE?
I just might do this as soon as I find a vendor that carries blinker fluid, and muffler bearings.
