RockMonkey
- Salt Lake City
That's going to be one heavy skid plate/crossmember... I learned several builds ago to build skid plates and suspension crossmembers separately. You can build it all as one peice, and that works fine, but if you need to fix/maintain anything, you have to take your whole suspension apart to do it. Build your crossmembers to take the forces of the suspension, and bolt your skid plate up only as protection from rocks. That makes everything lighter and easier to work on. Skid plates don't have to be nearly as thick as 1/4" if all they are doing is keeping the rocks out. I would build the crossmembers out of square, rectangular, or round stock, rather then thick, heavy plate. If you build the strength into the structure, you can save a lot of weight (and money) by using thinner materials.The only thing I'm concerned with is strength right now. . . It's all 1/4" plate, but flat with the ribbing welded in for support, I'm just not sure it's enough for the radius arms mounted to it also. I'll probably end up running some 1/2" plate under the tcase, to recess the bolts, and to beef up where the mounts will be. If you don't mind me asking a couple questions about your build, what angle are your arms at? I'm was thinking of quietly stealing your idea.Also, what's the distance from your front spring hanger to the center of your front axle? I lost my measurements on the location of the stock front axle and don't want to push it to far forward. I was shooting for about 3" forward. thoughts? help. . .
By front spring hanger, do you mean factory lower control arm mount? I'm not sure on that, but I can probably measure it sometime this weekend. What angle are you looking for on the control arms? The angle of the arm to the axle/frame, or the angle of the arm to the ground? I moved my front axle about as far as it would go without hitting the pitman arm or drag link joint on compression. 3" sounds about right.
