In my opinion the issue is not the quality or durability of the Detroit, rather, their warranty policy.
What I'd like to know is what happens to other lockers when a shaft breaks.
If breaking the shaft on an ARB or whatever takes out the locker then it is normal to loose the locker. If not, then it is a weakness of the Detroit and the warranty should cover it.
If loosing the locker is normal with shaft breakage, I'd like to know what other companies do in this case. If every other company covers it, Detroit should also because it is the expected industry behavior unless stated otherwise before you buy it.
If nobody covers it, tough luck.
I beleive that to judge Detroit we have to compare them with the rest of the industry.
Driving with a broken shaft is OK by itself, assuming that you know that there are no broken pieces floating around to make things worse.
Naturally, if there is no other choice, you do whatever it takes.
