but the D60 is full-floater with a much stronger gear-setDan Turner said:Again, not trying to be argumentative, but I stand by my thought process. With a 37-39 inch tire, MOST wheelers will not break a 30-spline rear 60. To take it a step further, if you ARE breaking axle shafts in that tire-size range, you may need to take a better look at your driving abilities rather than your equipment.
dion
30 spline Dana 60 axles are the exact same diameter as the Dana 44, 1.31 inches. If that's your argument, why bother with a 60? How many D44 r&p's have you broken?
Dan
I was just putting in my $.02 about the axle shaft strength debate. Full floaters are cool. Just ask Fullsizexj how strong the floater 30 spline shafts are.mad maXJ said:but the D60 is full-floater with a much stronger gear-set
Blatant said:Personally, if I were running 38x12.50 TSLs (which are a smallish tire), I would run a regular 30-spline dime-a-dozen 60 in the rear. You should be able to pick that axle up for $150 every day of the week.
Dion
Goatman said:Oh, so now 38's are SMALLISH ? And 44's are average size ?
Yeah. The penis-envy ego-based rig building sure seems to have gotten out of hand. My rig worked very well with 31s and a rear locker. Wheeling was fun at that level. 38s are NOT small tires and I would venture to say are the upper limit for sheet metal based XJ's.
I wheel this past weekend in a YJ with open front, 5 sp, 4.10s, and 35s. It was challenging and fun as hell. I think I might build Marni one of those next.
Blatant said:As stated, if both are dually axles, you're going to run into width issues vs. a full-width front 60. Strengthwise, it's a toss-up. The Corporate axle will be a bit easier to set up R&P.
Dion
SeanP said:Yeah. The penis-envy ego-based rig building sure seems to have gotten out of hand. My rig worked very well with 31s and a rear locker. Wheeling was fun at that level. 38s are NOT small tires and I would venture to say are the upper limit for sheet metal based XJ's.
If you sold a 30 spline 60 why would you get a 30 spline 14 Bolt? If you're already thinking of 42s i think there is no choice for you. Get the 70, you can't get enough beef and choice of gears for 42s.macgyvr said:I just sold a 30 spline d60 cause i wanted to run a 14 bolt or d70....
i'm running 38s for now...42s are always a possiblity....
what's the width difference btw the d70 dualie vs 14 bolt dualie vs a reg non dualie axle and are they mods i need to make to the dualie axles to run single wheels....
mac 'have watched too many d60 30 splines splinter' gyvr
XJoachim said:If you sold a 30 spline 60 why would you get a 30 spline 14 Bolt?
mad maXJ said:30 spline 60s very rarely have problems on 38.5 SXs, and the 38s he's talking about are a fair bit smaller, narrower, and lighter.
however, if you think 42s are in your future, then you need to think a little different. If I was considering ever going larger than 37s, I would definitely be looking at a hybrid axle, probably 9inch center with 14b ends, search for SeanP on that one.
Blatant said:If you read what I wrote carefully, I said the particular tire the poster is running is a "smallish 38"; meaning that tire runs a little smaller than the average 38, more like a 37.
I'll be running 37s on my rig when it's built. I ran 38.5 SX on a welded 30-spline 60 in my last YJ and it survived for the years I owned it on most of the upper-level AZ trails. Far as I know, the guy who bought it is still running the same axle.
(shrugs) This wasn't meant to be a pissing contest. I've got the direct experience that I make my build judgments on. Beyond that, you guys run whatcha like.
d
