Exxon Valdez Jeep
- Temple TX
yeah, and then I'll have to change it all again when I do a 4wd swap. :confused1
Do you know the dimensions of the F67 pack?, is 62" along the arch?, what is the eye to eye straight across?jim i totally think that you should set the mj up with a giant 64" kit for the rear.. with a set of king link killers... that thing would be badd ass setup. or even run a pair of 62" spring unders. deaver f67. im done a good amount of research on this.. with that setup it will pull an easy 16-18". probbly have to c notch the frame to allow for clearance. prbably get a setup like this around 1k but well worth it
Not on the MJ, XJ yes.No linking the rear?
Is this thing done yet?
