collection of jeep stuff(build/blog)
summit racing usually has that stuff for 20$.
:hang:Well damn.. the end of the tj arm that mounts to the steering box has too small of a diameter haha.. sorta found out the hard way. after drilling it to 1" with a dewalt cordless and wasting my spacer by welding it in
Thats very strange, I haven't seen anything about them having to be modified at all. That thread I posted a guy went from a yj arm to an xj no problem. Unless theres a difference between the tj & yj arm, I don't see an issue. What year did that arm come from?
should be the same Pat, I am pretty sure TJ guys use XJ boxes and XJ guys use TJ boxes, and they all use the same PSC boxes. Did you evaluate the master splines to make sure that maybe the TJ doesn't have more master splines? you can shave them down and file them down if so.
I'll start the bid at 25$. haha
Jd2 model 3 is a nice bender. I have a pro-tools 105 and it works. I like it. If I needed to buy another bender down the road, I wouldn't mind giving the model 3 a shot to see how I like it. IMO they're pretty equivalent benders so it really boils down to which is cheaper and in stock when you're buting
