Hey, get this crap about D44 vs D30 out of my thread!!!!!!!!!
I brought up the thought of purchasing ONE expensive HP 60 axle, combining it with a $20 HP 44 housing (and a number of other specialized parts) and getting a HP D60 rear AND a HP D44 front running D60 shafts/u-joints for perhaps less than bucks than all other options. Sure, one has to add in custom shafts (front and rear), high steer, custom bracketry, aftermarket housing ends for the rear and other misc. items, but one usually has to add these to just about any axle combination they build. Price goes up, but does it go up to the extent of ordering a Tera60 and Tera50 housing from some builder company? I don't know. What I wanted to know is if what I outlined would work and if it would be worth it. I found out some would work and some wouldn't. There may be other better options too. So lets keep it on topic about the custom axles. Here are a few more questions:
Will a stock HP D60 modified to run in the rear work ok or will oiling issues make it have problems? Are there modifications to the housing to make the oiling issues less troublesome?
Is a hp D44 center section combined with D60 outers and shafts with D60 joints a reliable combination or will the pinion or something become a problem area? Is there really a 35spline D44 ARB and does it cost more than a 31 spline D44 ARB? How much more? How about a 33 spline ARB? Can a 31 spline ARB be upgraded to 35 spline by swapping side gears? Are D60 alloy shafts more expensive than D44 alloy shafts and by how much? Who makes the custom length D60 shafts since I won't be able to call a Warn distributor and order stock replacement Alloy shafts. What about the axle seal in the diff? Anybody make one that will work?
If one were to do one of those custom 9" housings with 60 outer parts, what do they do for axle seals in the diff? Can the same thing be done with a D44 housing? What size tubes do they use? Since the 9" housings started life as rear ends, is there a place to install an axle seal in the diff? If not, how do they make a place for a seal when modifying a rear housing for use in the front? Just a few questions ON TOPIC!!
Jeff
