Jeff 98XJ WI said:
I brought up the thought of purchasing ONE expensive HP 60 axle, combining it with a $20 HP 44 housing (and a number of other specialized parts) and getting a HP D60 rear AND a HP D44 front running D60 shafts/u-joints for perhaps less than bucks than all other options. Sure, one has to add in custom shafts (front and rear), high steer, custom bracketry, aftermarket housing ends for the rear and other misc. items, but one usually has to add these to just about any axle combination they build. Price goes up, but does it go up to the extent of ordering a Tera60 and Tera50 housing from some builder company? I don't know. What I wanted to know is if what I outlined would work and if it would be worth it. I found out some would work and some wouldn't. There may be other better options too. So lets keep it on topic about the custom axles. Here are a few more questions:
Is a hp D44 center section combined with D60 outers and shafts with D60 joints a reliable combination or will the pinion or something become a problem area?
Jeff
Jeff, I can tell you what I did, most of which you already know. I had a HP60 hub to hub sitting in my garage, and a rear full float D60. I wanted to do what you're talking about, but I would have put the full float ends on the front housing, hog out the spindles and use 35 spline full float shafts.....no seal issues. I also had the HP44 for the front, and was going to use the D60 outers. In my case, the 35 spline ARB wasn't out yet, but I wanted to use the 33 spline Detroit that came with the Super 44 kit. Unfortunately, Superior had an exclusive on the 33 spline Detroit so it was not available. There was a possibility that I could get one, but with difficulty. At that time, guys were resplining the stock D60 shafts to 30 spline to run in the D44/D60's, but they weren't holding up because of removing too much case hardening. After messing with it for a month or more, and calling around to see what I could get done, and what parts would work, I ended up selling the front D60, built the HP44 for the front with Warn shafts and CTM's, and bought a Tera60 for the rear. I spent a little more, but it all works.
As far as breaking some D44 parts, the one side was totally because of towing Poomba on Fordyce. I first broke a Warn hub, then two days later the stub shaft broke and didn't even make any noise....about an inch of the shaft just disintigrated, obviously from previous stress. I wondered how the other side would fair, and sort of waited for the other shoe to drop, which it eventually did. The stub shaft broke, not even in a bind or hard situation, and without much noise, and the break looked just like the other side.....not a shear but breaking up in little pieces. It likely was due to cracks from the previous stress.
I also have broken two CTM's, one on each side, and both were first generation which were before they were cryo treated. The first one the tire got caught in a crack, and the axle yokes were hitting. Axle yokes hitting has been the number one reason for CTM's to break. The yokes were clearanced, so that isn't a problem anymore. The other side broke, but not in a bind, though I was working it pretty good. It could have been from previous stress (maybe the same Fordyce situation), or from the bushing being a little worn and loose, or a combination of both.
I'll have to see how it all holds together over the next year or two to see how it is really holding up.
