BJL913
- Westminster and Highlands Ranch, CO
I was looking for something cheap like this, then decided against it and blew almost that much on guitars and a new amp this week... grrrr!
Man...this looks like a pretty sweet XJ to get
http://fortcollins.craigslist.org/cto/2717121445.html
That yours? If so I have some questions about your replacing the brakes to get rid of that Bendix-9 nastyness!
swapping an early single diaphragm to late dual is pretty easy. you'll want to swap the booster, master, pedal assembly all at once because there are a few designs and they are slightly different... only other possible issue is the brake light switch, they mount in different ways on RENIX vs OBD-I/II. Not sure if there are any switch mounting changes from 91-01 but I don't think so. Compare the brackets and see what you think.
Unfortunately, it's a little more than that in this case. Not a single diaphragm, its the bendix-9 craptastic ABS. Ask Troy and Keifer, they saw it on Tony's jeep at the last meet/greet. Pure madness! I think it will be straight across though. We will see on Sunday. Already got the dual diaphragm from Troy
