Got a lot done on the upgrades, still a lot left to do. Winding back to the beginning and working through here:
The parts I'm working with are the JCR 3/16" mid frame stiffeners, Stinky Fab long arm brackets, Synergy long arms with the dual-durometer ends, Iron Man 4x4 forward leaf hangars, and HD Off-Road no-lift shackle brackets.
I had to make some mods to get the SFR brackets working with the other parts. For one, the ears had to be spread to fit the Synergy joints. And I had to notch the TNT HD crossmember to fit the LCA mounts. A local guy that does metal work on the side did them both.
I was originally planning to install all the brackets directly to the frame rail and cut the stiffeners to fit, but the SFR brackets are engineered so that they can fit over a frame stiffener as well. However there are some clearance issues that have to be worked out. In particular I found that I had to remove most of the pinch seam, so I decided to just cut it flush and tack weld the halves back together. I cut all the way up through the LCA on the same line, then came back and tacked them back together. More tacks than original so should be okay.
Also chopped the stock UCA bracket to make room for the upper arm
With the frame rail clearanced we cleaned the undercoating off with a 5" knotted wire brush (fast), then sanded and cleaned the areas for welding.
The rear end of the stiffener goes all the way back to the stock forward leaf hanger, but the Iron Man 4x4 hanger comes up forwards a few inches, so I chopped the end off the stiffener before welding.
After welding it down, packed the seams with sealer and covered with primer, then marked and sanded the areas that needed welding for the SFR brackets
The Synergy arms are designed to install with the adjustment clamp at the top rear of the arm, however the clamp interferes with the SFR bracket, so I had to swap the arms left-right to and turn them upside-down (had to swap to keep the curve for the tire inwards).
Another problem: the SFR brackets are designed so that the hard lines on the driver side can run between the bracket and the frame rail, but with the stiffener pulling the bracket over the gap is pretty tight. In particular my 91 has the quick connect for the high-pressure fuel line in that gap, and the bracket would not install over it.
The first attempt to fix it involved cutting a 1.75" hole in the side of the frame rail that the fitting could recess into, but I did not like the idea of having the quick connect trapped in there with the welded bracket. So I changed up and routed the lines over the bracket instead. It gets a little busy there with the UCA and the driveshaft but everything seems to clear alright. I am probably going to cut some rubber hose and splice over the hard lines to provide some padding but it seems alright for now.
Final install with the JCR stiffeners welded in, and the SFR brackets welded to the stiffeners. Uppers are set for 29.5" and the lowers are set for 31.75", almost twice the length of the short arms I was running before. The lowers curving down presents a couple of minor issues, but also presents some opportunity. For one thing they are likely to drag, but they will also act as belly skids for some things, which is good. They also gain a lot of room for travel at both ends (up-travel at the frame and down-travel at the axle).
After it was all bolted up I did a little driving around in the yard and cul de sac, everything feels good. Have not tested travel or anything yet, but I did put one tire in a ditch and it stayed planted the whole time.
4-day weekend coming up for Thanksgiving, so I will try to get the rear brackets installed with the RE 4.5 leaf packs. After that I will come back to the front axle and install a set of MetalCloak coils and do some other work. Then I have to fix the doors and heated seats so I can go winter wheeling.
