- Middle Tennessee
GWNF??
looks like fun.
George Washington National Forest
GWNF??
looks like fun.
Yes it is. We came down H and found a lot of ice patches so thought we would go back out on Power Line and found that one large patch. Once we were past it and on the big climb it was no problem. There are some cutovers from H to Power Line further where we were, would have been best to come up H until ice then cutover to Power Line for the climb.Lot of ice there. That Power Line (the primary, steep climb out from the West/South)?
Everything is running top-notch EXCEPT the transmission is not acting as I expect on the highway. For one, fuel mileage is down to ~10 MPG when it should be closer to ~14. Also the transmission has not been running as cool as I would like--I installed the new coolers which addressed the symptoms (runs much cooler), but thinking about it I should not have to put 15,000 BTU cooler on the trans to make it run in spec. Both symptoms point to torque converter clutch engagement issues, however the TCC lockup seems to work just fine--I can feel it shift and RPMs drop as expected. My working theory at the moment is that the old solenoids have damaged o-rings and are not sealing the hydraulic circuit for the TCC fully, allowing some fluid loss and therefore some slippage. I am going to swap in the set of aftermarket solenoids again, and see if they work better.
