Ball joints
Your driveway? :) Actually the preferred place to do axle work is usually on the trail.
Lunch break while you're at work, in the parking lot?
I've done worse :eyes:
I have a lot of time right now got laid of till Oct. so bring it by. I just did my 60 on my van upper and lower. I bought the parts at the 4WParts annual sale for almost 1/2 off and they are spicer. Got the tools, press all you need. Not that hard to do. The hardest part would be if the hub doesn't want to give up the axle.
Why would you need to.seperate the shaft from the hub?
pull the whole thing out as one
Yeah your right. I was thinking about the one ton 60 can get pretty heavy with all the meat hanging on it. Never done an XJ/YJ/TJ/ZJ so I was just thinking HEAVY.
ZJ I'll check my box, I haven't been here for a while!
