Ball joints are finally complete. Had to put a new boot on the tre, grease everything, put new disk brake bolts in and new hub bearing bolts (all grade 10.9) realign the disk brake cover, put the other tires on, install my new air shocks, and make a mounting bracket for the fill nozzle.
Still need to install new rear air shocks along with a new lower shock stud and probably all upper bolts will be snapping off, steering stabilizer, fix mounts on the exhaust and then I can put my power heated mirrors on, 12ga upgraded headlight harness, Silver star headlights, thermostat, oil change, fluid change on all the gear boxes, and finally the plow. :wow:
Stud mount shocks suck when one of them has rusted to where you cannot see the threads.
