Safari Ary
- Virginia Beach, VA
Well, I finally made it home. I had to stop over in Chapel Hill at Motorman's house to swap axle shafts in the front end, re-install my front DS, pull the rear DS, and limp it home in FWD. Now here's my problem. When the rear DS is in, I get a sound that would make you think a helicopter was about to land on you, but it only occurs when the gas is applied. When I'm coasting it goes away. The DS appears to be fine, i.e. no visible play in the u-joints whatsoever. This is an RE/Spicer DS that I got with my hack 'n tap SYE. Anyone got any ideas? Andy Zuber(of the carolina rock shop) mentioned it might be a toasted pinion bearing. Any other ideas? Thanks
Ary
BTW, this is an 8.25 rear end with stock gears, tires are 33s
Ary
