Back from Tellico with problems.....rear axle woes...
A couple of thoughts.First, now would be a good time to check the bolt to make sure it doesnt bottom out to soon.Secondly, its unlikely that the broach(splines) in the hub is completely cut flush at the bottom,if the shaft doesnt have any chamfer(or very little) the hub may stop short of being fully bottomed out!
Jump This said:
have credit card????
Nope, 'cause if I did, I'd be in debt up to my eyeballs
When I first did the SYE I made sure the bolt wouldn't bottom out first. I know that's not the problem. I don't understand what you're saying about the shaft having chamfer(what is chamfer?). Thanks
Ary
Its a 45*bevel cut like what was on the end originally.BUT after reveiwing all the photo's I realized how they make these things.They are 3 pieces,Im actually suprised they dont have more problems with them.Even when tightened down it can still move.The HD kits are definately the way to go!!!!!!
