squareone97
- NV
Hello!
I decided to upgrade my XJ to ZJ rear disks. What a great improvement!
My issue is that while helping me reinstall the axles my nephew rotated the diff and spun the spider gear thrust washers out. Because of how tight everything was due to the trac-loc I had to pull the carrier to reinstall the thrust washers
I have no experience with differentials so this was a large learning experience, even made a tool to reach in the axle tubes to adjust the backlash
I reset the carrier to .005 backlash and torqued the betting preload to 75ft/lbs
After driving home from my sisters I noticed that the diff rumbles pretty good at 65+ but is silent slower then that. It’s a lot like a rear u joint vibration.
There is also a serious clunk from the diff when shifting into drive.
I’m pretty sure the backlash was set wrong and is too loose. I patterned the gears today and have a dial indicator coming tomorrow to verify as the one I used was borrowed.
I’ll include the gear pattern pics so maybe a more practiced eye can chip in some feelings on it
Drive side
https://ibb.co/8zb59TF
Coast side
https://ibb.co/pwKxHDK
Drive side
Coast side
