AX-15 w/ 231 T/C
BiggerIsBetter
Livermore, CA
I'm swapping out my BA-10 and looking for an AX-15 to put in its place. The transmission and transfer case MUST be in working condition, I don't want to mess with rebuilding it. The shift linkages, crossmember, and hoses would be a plus too.
Thanks,
Chad
i have a 90 with ax15 and np231, where are u located, im in new milford, ct. they are still on the jeep, make an offer. i can pull them, but that would affect the price.
[email protected]
-chris
[email protected]
-chris
I live on the opposite side, CA 94550, so I would need you to pull them. Before I make an offer...how many miles are on the setup? And, since I am doing a swap I would need everything, including bellhousing, transfercase linkages, and all the necessary hoses and bolts. Does it include the clutch and flywheel?
Thanks,
Chad
Must sell as a whole deal.
4.0 high output, 5 speed, np231, 30" mud tires, stock rims, rancho 5000 all round, 2" lift(spacers&add a leaf), pro flow muffler, new crank sensor, seats were just out of upholstery, new water pump and radiator, cd player.
I never took this jeep anywhere but on easy trails and daily driving. Motor was babied from day one, always used 91 or better octane fuel, oil changed every 3k miles or 2 months(hot here), tranny, transfercase, both diffs were just serviced as well at 90,000 miles.
I have spent over $4k in this jeep.
Pis available!!!!
First $1,250 takes it all........
Will deliver within 250 of Southern New Mexico anywhere after that will be an extra charge.
I also have a complete master install kit for both diffs(Dana 30&35) 4.10 gear set. Comes with Timken bearings, shims, 30 carrier as well. All you need are the tools to install.
First $350 takes it. I will ship anywhere for a price!!!
PM'd you.
Pis available!!!!
