Another build thread.. Shamu rebuild
So I've got a set of flat top knuckles I got from Dan but have been putting it off since I'm not sure what to do about the panhard on the cast wedge axle.
I've seen this done a couple times, just not sure how well it would work on the ford axle...
UMmmmmmmmmmmmmm do what all the cool kids do and get rid of the wedges :greensmok
Ram" Just saying" Rod
Finally got the ring & pinion out. Also found the short side u-joint is shot.
Pretty sure some foreign material caused that. Probably a piece of previously broken shaft. That gear set is at least 6 years old, I'm fine with that.
Got it back on all 4. Set the ring & pinion yesterday. Got a great pattern, didn't have to move the pinion at all from the previous set up. Ready to go tomorrow for Blessing
Ordered some center mounted limit straps for the front. May be taking over DD duty for a few weeks when the WJ is in the body shop.
Drove the silver jeep around all weekend back home. Loving the doors off.
