cox_xj
- Bradenton Fl
i have steel d windows, and i've spun them up at work to check the balence and they dont balence out, but i can see that the wheel isn't bent, just the bead has a nice dent on a few of the wheels
cal said:I used to run rock crawler 15x8 D window wheels, steel. New, if you threw them on the tire machine and spun them up with no tire, you could see 3 of the 4 were not round.
Thats why I run alloy wheels now. An extra $15 bucks a wheel and all the difference in the world.
85xj4dr said:I just swapped tires and rims last night, and balanced with airsoft BB's. It works great. Its actually smoother than when i had my wheel weights on.
Good ol' bi-mart. I forget how much exactly, but they were cheap. Either that or go to walmart.WheelinJR said:hey you're local, where did you get em. I've got new TrXus coming and want to use this method.
WheelinJR said:word, now i need a scale.
cal said:As far as volume goes, it will fill a tennis ball.
Its somewhere around 9 ounces if i remember right.
WheelinJR said:The chart tells me 8 oz for a 33x12.50x15
WheelinJR said:I only play with real guns, haha.
