GhostDakota
- Phoenixville, PA | Bethany, DE
I forced my product guys to put the e-codes on our site now too
http://www.quadratec.com/products/97052_9000.htm
i know a couple people whove had a lot of problems with the fatboys burning out. im running the eaautoworks harness on my jeep (with GE HO sealed beams) and on my subie, but a 40A version, with osram +90 nightbreakers. those are headlights.
When converting to halogens its almost trivial to base your decision on how much light is produced. I mean what ever K you get, it is going to be like 10000X brighter than halogens. You are splitting hairs in my opinion.
Well that and the lighting benefit to HID is getting the light to be in the same color range as daylight, which is what our eyes see best with. Less eye fatigue at night.Wouldn't bet on that statement. My H4 produce about 3100 lumen on High and about 2400 on low. Compares quite nicely to the 3000 lumen the 4K HID does and beats the 6K and above. Of course the H4 draws about 4x the current and need to be replaced more often.
Hows the IPF housings, do they spread the light evenly? Rampage MSR's have hot spots. (brighter in two spots)I just have some IPF H4 housings and some Xenon bulbs.. working on a upgraded harness for lights.
im not ready to do upgraded lenses yet, i still need to rewire my factorys with the new relays and bigger wires first... i also need to do the 4 guage upgrade for my alt/starter/batt/ground
4 Gauge? What?
i was thinking about using 4 guage from the battery to the fuse box the little short 8" hop, then from the battery to the starter, then from the alt to the battery or however those wires go, i know you sell the kit and its said to be real clean, but idk if i have the funds to buy a ready made kit... i also want to do the hi/low relays for my factory lights to make them brighter and prepare them for aftermarket housings and bulbs.
The relay upgrade is a good start. Will allow the use of high wattage bulbs once you go to the after market H4 buckets. You can do the whole job pretty cheap if you build your own setup rather than buying a kit.
not really, the eautoworks kit is really cheap shipped, and it's one he'll of an upgrade.
Well worth the 30$, saves time too.
