mybrosride
- Orange Co - SoCal
hey guys thanks for all the help so far... I may pop back in after I check some of these site out....
I'm pretty sure there's at least one thread on about every light upgrade available if you search around here a bit- harnesses (who sells what, how to make your own), housings, bulbs, HID, projectors, pictures, thoughts, opinions, how to aim them... and so on.
i'm looking at 6k and under lighting...All factory HIDS run 4300kelvin, and they produce ~3100lumens
Higher kelvins = less lumens = less light
6000k = 2900lm
8000k = 2500lm
10,000k = 2300lm
etc...
Ok, BUT by that logic there's nothing wrong with a 30,000k HID kit either because it produces ~2000lm ... which is more than twice a halogen's 900lm. Of course, I dare you to drive down a highway at night with dark blue HIDs lighting your path. You'll go mental after a few miles because the human eye is most comfortable with something that resembles daylight. Obviously, I'm not saying 8,000k is the same as 30,000k, BUT it is darker than 4300-6000k, and it will affect your driving comfort at night.
if you are ricer, then you HAVE to get 30k:twak:
IMO, 90bucks is too much for those headlights. I would go with autopals.
Ebay, wreckers, teamcherokee.com (email them, they might have them).
-- I saw this thread and had to add in my experiences with them. From what i skimmed thru, i noticed that NO ONE mentioned the MOST important thing....
-- ALL OF THE WIRING NEEDS TO BE UPGRADED,, ALL OF IT!!
-- If you dont swap out the stock wiring,, or in some cases you use the "wires included" way,, DONT!! There NO better then stock.
-- OK, i guess i just cant say upgrade your wires and then leave,, SO,, lets say i took a 100% stock XJ, and took out the stock headlight wiring and LEFT IN the old, old lights that still work,, as soon as im done with the NEW wiring, you wont believe the difference even when your standing right there!!
-- Long story short,, if u stick in ANY H4 bulb OR ANYTHING with higher lighting power,, you MUST upgrade those skinny wires and replace it all with some nice thick wires,,, and while ur at it,, make a second ground for each light and or relay, AND CLEAN each connection and make sure the connection is SOLID,,, then on EVERY ground wire, GRIND TO BARE METAL FOR MAX CONTACT on each and every ground that you have.
-- Stainless washers and lock washers are always good to use if ur screwin down a ground connection.
-- Hope that helped!!!
Maybe thats whats wrong with my HID setup??
The passenger side bulb flickers on startup and idle. Drivers side is fine.
I think that could def. be it. How many watts are the HIDs? I know a lot of people who run 55w HIDs have to run an accessory harness straight to the battery because the stock wiring doesn't have the juice to fire them up. Might not be a bad idea to do that, especially since they are only about $20.
Some diamond stuff's dope:Don't go diamond anything.. they are crap
