davelbert
NAXJA Member #1079
- N. Las Vegas
I believe you can use most parts from 97+.
the TPS is very sensitive to water. Dunk it and it's usually toast.feerocknok said:So, it's the TPS. Thank you.
Do these sensors get tripped?
Our AutoZone is still in construction, can I get my computer checked anywhere else for free?
Can a replacement sensor be pulled from a junkyard if this one's bad? Off of what years?
Thank you all for all the help.
87manche said:how many times did he change the fluid in the pan? Draining the pan gets 4 of about 12 quarts. Gonna have to change it 4 or 5 times.
feerocknok said:I don't quite understand. I wasn't around when he did it, but I believe he drained the whole thing.
exactly, drain the pan, fill with 4 quarts, drive for a mile or so, drain the pan repeat 4 or 5x.99XJSPORT06 said:Just dropping the pan doesn't get it all out. The rest is inside the Torque converter....which is why you'll have to change it a few times
87manche said:probably not, you'd still have contaminated fluid in the valve bodies and all the passages. and the cooling lines and radiator.
Either have it flushed at a shop, or do the fluid in the pan a few more times.
