A few steps closer to NAC-FEST, ROBZ95XJ Edition
NHextremeXJ said:
nope, im gonna use a YJ yoke and mess with shims for now, but the rear important things are a adj. track bar and control arms
that looks 100x better, when are you putting the tsl's on?
i really think im gonna run 31" LTB's on 15x8 Soft 8's w/4" BS
well whatever.....when are you putting them on?
ajpulley said:
Hey Rob, how long d'it take to replace the coils? I'm just about done with the rear and the front will be next. I should be at 5 and 5 1/2 too when I'm done.
maybee a hour each side heres what i did
remove swaybar
unbolt brake caliper
shocks
lower control arm at axle
the driver side was easy but the passenger side i needed a pry bar to get the coil in.
when io get the money, i got to get other things first i may just show up to nac fest with 5" of lift and 30's
I thought you needed an engine or rearend or flexplate or something?:dunno:
well im gettin a early start for next years Nac Fest, picked up some 36" Iroks today, big thanks to matt6669 for the hook up
matt6669 said:
np rob anytime man, if you need anything else just let me know
ill be in touch with you and joe in the future about frt springs, shocks and a few other misc stuff, thanks again
rumor has it that some knucklehead has gotten lots of goodies for his xj in the past few weeks and is gettin even more stuff in the next few weeks :D
Yeah, after that same knucklehead decided to sell the 36"s he was so happy about just a few posts ago... :laugh3:
well knucklehead came to his sences and relized that 36's cost to much to run at this point, so 33's it is
stuff gotten so far
shocks
coils
tcase skid
wheels
leaf spring bushings
rear brake line
stuff still needed
rear 3"bds leafs
control arms
track bar
pitman arm
frt brake lines
(all of above i should have with the next 2 weeks)
motor
floorpan
axles with deeper gears
lockers(lock rights)
tires (33"MTZ's)
im sure im forgettin stuff but o well
Slowest. Build. Ever.
--Matt
