RockControlXJ
- The Woodlands, Tx
Looks great, gotta love the low trucks. How high are you at the belly now with the 3" lift??
RockControlXJ said:Looks great, gotta love the low trucks. How high are you at the belly now with the 3" lift??
Zebaru said:Sorry, no pics, and I have no idea about an ax-15, but on the AW4, it was really easy. So easy in fact that I did it without reading about it first or anything. Just looking at the back of the tranny convinvced me it would work.
The adapter on the back of the AW4 is easily removable, and there is about an inch of clean flat space clockwise of all the bolt holes (like it was designed for multiple clocking angles).
I simply took that adapter off, scribed some new hole markings, center punched them, and drilled them out on the drill press... I am not sure I would have tried it with the tranny on the rig, but I am sure it could be done.
The t-case shifter fit fine, but doesn't shift as smoothly as before. Perhaps with some adjustment, that would be fixed. As it is, it works, so I have not taken any time to do anything about it.
Also, with as far as I rotated the case, I had to really hack into the floor for clearance, both for the case itself, and the driveshaft. More lift might resolve the driveshaft issue, but raising the case an inch is just like lifting an inch, so you will end up with driveshaft bind sooner...
JeepinCoastie said:good luck if that winch line snaps....
like it but i wouldnt do it ...
XJ_ranger said:any thoughts on heat protection? perhaps look into www.winchline.com 'fireline' which has a much higher melting temp than other winch line...
That would be my main concern with the winch there...
awesome ideas, great exicution.
Zebaru said:I wont be doing any winching with a passenger in the seat, and I feel pretty okay with sitting a couple feet to the side.
There shouldn't be alot of stored energy in that line. I have seen several synthetic winch lines snap under load, and in each case, they simply fell to the ground...
Even so, this may turn out to be a bad idea - but I rarely have a passenger, and I didnt want a winch hanging off the front, so I figured I'd give it a shot.
