5bucks
- Rochester, NY
1999 XJ, Air conditioning works great for about 20 minutes then slowly gets warmer. If I turn the air off for 10 minutes or so I can turn it back on and everything is great again for 20 minutes. As the vent air gets warmer, the volume of air through vents decreases. To me, this seems like classic sign that the evaporator is icing up.
In my research I've come across 2 potential problems. Either low refrigerant or a switch that cycles the compressor on/off to keep ice from forming on the evaporator.
Anyone aware of a common problem and/or way to test the compressor cycling?
