I agree also tension gauge is needed
Even the armoured personnal carriers had adjustable tensioning with a little gauge in the housing to see if the tension was correct.
One thing though, what you tkink is the correct pressure of 190lbs by your 'feel' is closer to 90lbs. Pick up a Krikit II from napa for $12 bucks and take the guesswork out of it..
