- NE Texas
Well, I had planned to do my Add a leaf to bring the rear end up more today..
but, I woke up on a mission to fix the crappy Idle.. I've got a Thread going in OEM tech about Renix Idle.. And i finally solved the issue! After going through Every sensor with an Ohm Meter, and Adjusting the TPS, Everything checked out fine.. so, A few suggestions were to Check the Manifold bolt tightness..
Sure enough, 2 bolts underneather were missing, and one was loose, So.. after raping the Spare motor, I torqued it all down and FINALLY got my desired 800ish RPM idle :worship:
While in there, I installed some brand new Brown dog motor mounts:woohoo:
