jstlink
- riverside,california
blew my 89 4.0 xj motor.have a lead on a 92 4.0 to go back in the 89 xj.will this switch work?not sure what the major differences in the motors were from those years.
What about the other way around? Trying to put a 89 4.0 into a 92 xj?Forgot to say I guess...You do NOT need to swap any electrical or computers...Just move old sensors to new motor and it runs the same. 4.0 is a 4.0 is a 4.0. Some just flow a little better with the HO head.
Could just swap on the HO head on the RENIX block. Also, watch CARB mandates. OK to swap later engines in older vehicles, not the reverse. Yeah, most States won't check. Probably even those that Do.What about the other way around? Trying to put a 89 4.0 into a 92 xj?
I appreciate it! What I have going on is I bought a 92 xj from a guy that couldn’t get it running after swapping an 89 renix 4.0 into it. Renix block, all HO top and and accessories. It will crank but no start. The IAC and TPS are new, HO dizzy is indexed and engine is at TDC. CPS is reading about 3400 ohms(I’m not sure if that’s good or bad).Could just swap on the HO head on the RENIX block. Also, watch CARB mandates. OK to swap later engines in older vehicles, not the reverse. Yeah, most States won't check. Probably even those that Do.
Also, I think HESCO sell a wiring adapter to swap a RENIX to a HO Throttle Body.
Only skimmed it. I did put on a '95 HO Valve Cover on my RENIX. Also, a 93-95 ZJ Valve cover would be better. I did the Late Style Big Tube CCV Tube on mine. I had to splice in some tubing. Might not be a problem with an HO Intake.17 – HO engine into Renix
CRUISER'S MOSTLY RENIX TIPS HO INTO RENIX SWAP This swap is easier than some will lead you to believe. And generally Pooh-poohed by those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it ...comancheclub.com
That sounds to me like it's got the HO flex plate installed, which won't trigger the Renix CPS properly. [Edit: errrr...vice versa - Renix flex plate which won't trigger the HO CPS properly. Same problem, just opposite] You also won't see the tach wobble at all while cranking.Renix block, all HO top and accessories. It will crank but no start.
