As for an exhaust manifold, I wonder how these stainless jobs would fit? Something new I saw in the Speedway motors catalog. As you know, I used center dump early corvette stamped steel manifolds modified to fit...and no, the thing isn't operational yet!
http://www.speedwaymotors.com/Tru-R...old-Polished,53711.html?parentDisplayId=53710
Tru-Ram® Exhaust Manifolds allow you to enjoy the look of factory LS style manifolds, without the hassle of dealing with unsightly rust and corrosion. Investment cast from durable stainless steel material, these exhaust manifolds will be a low maintenance, high-performance addition to any LS-powered vehicle. Features a fully polished, show quality finish.
Tucked-in shape hugs block contour
Smooth internal transitions perform like shorty headers
Collector angle is optimized for maximum frame rail clearance on any application
Round 1-3/4" primary tubes
Large 3" collector outlet
Standard 3 bolt collector pattern
Includes stainless mounting hardware and gaskets
However, the cost is right up there with the Novak units. Novak ceramic coated $495, Speedway SS $550
Jeff
