- In a strange land
Here is an effort at some pics. I don't know how well they will translate to your situation, but this is at least what things looked like originally.
First pic is of the downstream O2 where it plugs into the cat (not an original cat, but a CARB OBDII approved cat, so it should be pretty close to what was factory):
Second pic has the O2 sensor plug in the upper RH corner and shows that wiring coming from the same harness as the VSS:
Third pic shows that harness going up the firewall. The bulge at the bottom left is the starter, and up above you can see the bottom of the carbon canister. The harness in question is the larger one of the two.
Lastly, just for some sort of reference, is the upstream O2. This is in a Borla header (again CARB OBDII approved) which differs a bit from factory, but the wiring harness is not modified in order to reach that position.
Hopefully something in there will give you a point of reference which will help.
