- Westminster, SoCal
OK, so I finally got my stuff bolted up Now I have couple questions:
1. Does the 4x4 light stop working reliably? It looks like the shift points changed a bit with the 2L so it'd make sense that the light would not necessarily work right.
2. Does the 4:1 with 2L and wide chain chatter a bit more then a standard tcase? The noise is a bit amplified for me cause of the Novak shifter, but I think this is a bit more noisier. It's not a grind, it's not a howl, it's nothing bad sounding, just light chatter.
