:dunno:I have been following this thread for a while. It is amazing the number of people on here uses 31" to 33" tires with stock gears and say it is OK. This conversation have been going on for years in other threads here at
. Yet I find it quite entertaining when I read other's comments regarding large tires and stock gears. It make me think my XJ is inferior.
I had 30" tires with the stock3.55 gears carring about 300 lbs of stuff in the back and it was horrible every where except on long flat highways. Then again onthe highways every miniscule incline would set the AW4 in a gear hunting tantrum (my cruise control set between 65 and 70 MPH). Shift the gear lever into 3, the RPM's at 3,300+ and watch my milage go out the tail pipe. My XJ achieves best milage between 2,200 and 2,600 RPM.
Mileage is important to me since I use my XJ to take me to work from Miami to Iowa, Maryland, Missouri, Texas to name a few. I used to average 17 MPG. Since going to 4.10, the get-up-and-go have returned. I could take off from a stop without the guy behind me honking at me. I could over take on the highway with out putting the pedal to the floor. I could cruise the highway and up and down hills and not have to worry as to wether or not the AW4 is happy. Most inportantly, I am getting 20+ MPG. I think the Xj could use 31's now with the 4.10 but ???? :dunno:
April 10, 2008
RPM’s at 55 MPH with 4.10:1 gears running 30” tires 1980
RPM’s at 60 MPH with 4.10:1 gears running 30” tires 2175
RPM’s at 65 MPH with 4.10:1 gears running 30” tires 2360
RPM’s at 70 MPH with 4.10:1 gears running 30” tires 2550
RPM’s at 75 MPH with 4.10:1 gears running 30” tires 2700
RPM’s at 80 MPH with 4.10:1 gears running 30” tires 2920
