They are semi floating instead of the full floating rear ends that have a hub.
Semi floating works like your Jeeps axle, where there is a bearing that transfers weight of the Jeep onto the axle shaft itself. The advantage to full floating it that you can pull out a broken shaft and still drive w/ no axle shaft.
