- In a strange land
I did read that the 2 door XJ are heavy doors compared to 4 door XJ and since Black Beauty's shut so nice want to keep it that way.
Frame plating is cheap insurance like mentioned, so will be searching builds on what all is involved.
Who makes best fitting? Not necessarily the thickest or most coverage.
Mount some tow hooks somehow.
Wonder if these would still fit after comp mount ?https://www.quadratec.com/products/76045_802.htm
With regard to frame plating, it is going to be hard to get a comparison of fitment as there are probably not very many folks who have installed a variety of different stiffeners, and even then, each set would have gone on a different XJ that probably would have brought its own set of variables to the picture.
What makes the biggest difference is the installer who takes the time to fit the stiffeners to the chassis. Lots of clamps and a few jacks are essential. And a willingness to remove all the clamps and jacks and readjust before welding.
As regards those tow hooks, my guess is that they would fit. It is a only a guess though, as I haven't seen a picture of those things installed. This seems to be the only pic:
But it would appear they mount entirely on the outside of the frame. That probably means they would not interfere with the Comp Mount as it mounts entirely below and within the frame. Here is a pic that shows what I believe is the area in question:
I would expect to need longer hardware as the Tomken brackets are sharing the same frame bolt holes as the Comp Mount, but they are on opposite sides, so I don't think they would interfere with each other. Note the bumper brackets also share those holes up front. That makes for a good stack of pieces you have to get to line up all at once. Probably doable, but don't tighten anything down until you have really checked that nothing downstream is going to be out of whack (like bumper to body lines).
I swear one of these days I am going to finish my Comp Mount install, running it through the factory bumper. Then I might have more to add. But at the rate I am getting things done lately I will be turning to you for lessons on that subject.
