hemiriffic
- Upstate NY
Asking $1000 or first reasonable offer - Have to sell it to pay some bills The sooner it sells the less it goes for!
Yep the pictures are from this spring ... nothing has changed with the jeep
If you need specific images let me know and I can update or msg them to you
Located in Otego NY
1996 Cherokee sport 4 door
6cyl 4.0L HO stock
4 speed automatic stock
NP231 Transfer case stock
Chrysler 8.25 rear stock
Dana 30 front stock
3.55 gears stock
3.5 inch lift - 3.5 inch FTS coils front , extended lower control arms
2 extra leaves each side rear from FTS factory spring rate
Sway bar disconnects in the front
31x10.5x15 Firestone Destination MT
runs and drives fine ... battery does not hold a charge but will jump and run fine.
Needs a joint in the front drive shaft - have been driving as a rear wheel drive around here
Needs the upper drivers door hinge tacked back in place ...
Theres a little rust here and there-some in the floor structurally solid rockers rusty of course
e mail me/msg me with any questions or for a phone number if interested [email protected] be sure to put jeep in the subject line
