TRAILREADYXJ said:If you want that much, you will run into the same problem I did going for 6.5". (read link for problems)
I ended up with more like 7" doing this, and the ride and flex is better than most lift packs. http://www.naxja.org/forum/showthread.php?t=901160
Best of all... it's still a bastard!
alrighty, so now that I've had time to read and re-read what's been posted... I realize that while I'm not getting in over my head I've definately bitten off quite a mouthful. How difficult was it to fab up those new mounts? Looks like 3/8th's plate with a simple design and a bandsaw/welder could have that accomplished no? am I right in understanding that you had to shim your axle from the front bringing the pinion down when using those f150 leaves? Doesn't really apply to me as I have to weld perches on to my 8.8 anyway. I know it's going to be hit and miss, but do you think between an f150 pack and my stock leaves I'd be able to attain my goal of 7.5"? Actually come to think of it, my stock leaves are pretty flat and saggy and prolly wouldn't help lift, might actually pull down. Leaf packs are $25 each side here so even at $100 for four f150's if it gets me my desired lift I'm laughing.
