Old December 3rd, 2018, 07:55
Brent T Brent T is offline
Re: 2 door Cherokee 01 with 25,000 miles... mild build for daughters first Jeep
Originally Posted by Anak View Post
Here is a link to the SFR WJ steering conversion package: http://www.stinkyfab.com/sfr-high-ro...ake-kit-xj-mj/
Whether or not to plate the frame rails is a call you will have to make. Given the pristine nature of this Jeep I would be hesitant to start grinding and welding on it, but OTOH, that plating should extend the life of the vehicle. So I am of two minds on the subject.
If you opt not to plate it then doing things such as the Boostwerks Comp Mount and a C-Rock steering box support would be the wise course. Boostwerks will support the sector shaft down low. Add the C-Rock kit to support the box where it mounts to the frame. Between the two of those you would be doing the best I can think of without getting into grinding and welding.
X2 on the Comp Mount and a steering box support. I have both, but no front frame plating yet. Wheeling on 35's pretty hard and no issues so far after 8+ years. Having said that, I've had mid stiffeners installed for several years now and I do have front stiffeners sitting in the garage, just too lazy to burn them in. At the very least, install an aftermarket steering box "spacer". The stock aluminum one tends to break and become useless.
Old December 3rd, 2018, 11:25
Red Mistress Red Mistress is offline
Originally Posted by Rob Mayercik View Post
This is your daughter's first vehicle - it's going to see far more pavement than trails. Why have that expensive piece of gear out in the rain/snow/ice/sun all the time, weighing down the nose and visible to theives/vandals/idiots?
The hidden-mount winch is trick-looking, but fitting it behind a stock bumper will limit your options in winch (there was a factory kit to do this, but it was designed around a 6000-lb Ramsey unit), and it pushed the bumper out 2-3 inches and required a "fill panel" to cover the gap.
My suggestion is to forget the permanent-mount winch for now. Find a nice aftermarket bumper with receiver for the front (JCR, perhaps), and cradle-mount with Andersen-style disconnects. Oh, and a locking hitch pin for when you do want it on the nose. Going this route also means you can skip over factory-style tow hooks (BTDT) - they work, but a solid, tied-into-the-frame (the 3 bolts/side the OEM bumper uses will NOT be sufficient for recovery) bumper with D-ring tabs
Some will say it's not as strong as permanent mount, but so far I've done OK with my Q-series 11K on a cradle, and seems plenty strong for what I've done with it.
There's also the argument that it sticks out a lot farther, and impacts approach angle. For some it might, but for me (got the winch when I was at 3.5 with 31s like you're planning for), and I never bump with it (maybe once or twice in 5 years it's kissed the dirt as I climbed onto or off something?).
Yes this XJ is daily driver, we have other Jeeps for trails. That said, no telling what she will do on her own.
Weighing the front end down of Cherokee has been my latest concern in handling of the XJ.
Can you tell big difference in handling when you have the winch mounted?
Guessing XJ still handles good with heavy winch bumpers?
Anyone have to run different heavier rate sway bars to compensate?
Brent T ... nice Red XJ you have, that's the cleanest exo-cage's I've ever seen !
Did you see big difference in tightening up front end after you installed Boostwerks kit ?
I actually had/ then sold... a NOS Jeep SE 295153 XJ / MJ hidden winch kit mount from a Jeep dealership inventory that I bought out years ago. The special winch made by Ramsey to allow pulling from the "mounting feet" was not included. Attached pic of kit installed on Red XJ Laredo:
The Boostwerks kit is much better designed, going to take fab work to fit the OEM bumper on correctly. From Anak's pics think I can make it work.
Pic of my 67 Gladiator with Jeep SE 246 "bubba gump" winch bumper extension with Ramsey PTO.
Old December 3rd, 2018, 14:09
devildog0's Avatar
devildog0 devildog0 is offline
2 inch front reciever hitch. Can be used for recovery and reciever mounted winches. When you are going somewhere you want the winch strap it down in the cargo area and breaknitout when needed, keeps weight off the front until needed. . Leave it in the garage when commuting, keeps weight out if Jeepnfor better mileage.
It allows you to keep stock bumpers and with trimming the air dam only as much as needed keeps the look low profile.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old December 3rd, 2018, 14:58
ocean_jet's Avatar
ocean_jet ocean_jet is offline
Originally Posted by Greenspan View Post
Ahhh! What are you doing!? Keep it stock! That thing belongs in a museum!
Yeah.... exactly.
Old December 4th, 2018, 12:33
As ya'll can see from pics of my Jeeps, I know all about collecting auto's.
Yea this 2 door XJ is low miles and mint, but I can't find a more suitable Jeep for the price for daughter.
I have learned in my 30 years of messing with Jeeps, that it's always better in long run to have patience searching & start off with nicer example then build to expected use.
That said, I know when I modify that value will decline from purist standpoint, but... she needs daily driver.
Other Jeep choices:
1. TJ/LJ not safe for young girl.
2. 4 door XJ, don't want her hauling bunch of friends as too easily distracted.
3. ZJ too modern but looks dated & only 4 door, see #2
4. JK probably best 2nd choice, but I owned one and didn't like. Plus they are rapidly declining in value & too common on roadway.
5. JL - too expensive
What I have decided is to Metalcloak 3.5"lift and see how it does on 31".
If it needs better brakes or re-gear, will swap axles either JK or custom.
If the sector shaft needs bracing, will either do receiver hitch or Boostwerks comp.
Only thing I can't decide is exactly what wheel backspacing fit without cutting fenders.
Old December 4th, 2018, 16:54
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
I will concede that the only time I'm out on the roads with the winch mounted up front on my truck is running between trailhead and camp (when I am also aired down and disconnected), and while it doesn't appear to me that it changes the dynamics of the front end, that's not the best data set to work with for "normal" street manners (street tire pressure and swaybar on). Since the receiver is centered between the frame rails I wouldn't expect much difference in roll terms, though.
That said, I wasn't alluding to the handling so much as the reduced F/E from the extra weight. As noted by someone else, I leave my winch in the garage when not wheeling, and when I do go it's strapped down in back until I get to the trailhead where I install it with the locking pin. Comes out again and goes back in the "trunk" for the ride home.
I run an old-style JCR Stage 4 front bumper (pre-dates their "Crusader" line), it's basically 2x6 box tube at heart, but it has the advantages of being pretty much the same weight as the OEM bumper is much stronger (it doesn't take much to bend the stock bumper, despite its apparent thickness), and tucks up against the grill nicely.
You can get away with 31s on the stock 3.55 gears like I am doing, but mine isn't a DD and I do find it lugging a bit on hills. Probably I should change to 4.10, but since it's the backup car now that's low priority.
Oh, and I'm running my 31x10.50s on the factory alloy wheels that came on my '92. Just a couple washers under the steering stops, and I was fine.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old December 4th, 2018, 18:08
DustyWagoneer's Avatar
DustyWagoneer DustyWagoneer is offline
All I am gonna say is I have watched Red Mistress do majik to FSJ's for many years, and NEVER once has he done something crazy bad.
Look at the pictures of all his red Jeeps.
Every single one is perfect.
Not to mention the level of parts this guy has (or gets) is nothing but mind boggling.
I am looking forward to his build.
Old December 5th, 2018, 10:50
Thanks Rob & Dusty
For possible future larger rotors upgrade... I want to run 16" wheel.
17" Wheels with 31" tires IMO don't fit the look of Classic Cherokee.
From my searching ... aluminum OEM Wheel are Icon 16x7" wheels which are correct for 00-01 XJ
Problem is they have 5.25" backspacing, whereas the 15x8" XJ wheels have 4.5" BS.
Quadratec makes a similar wheel 16x8 with 4.5" BS
Refurbished Icon's are about same price as Quadratec wheel.
I don't know enough about XJ like do you try to keep the tires tucked into wheel well for best clearance or push them out ?
Hear that the 97-01 fenders are smaller than 84-96.
Know about adding washers to limit steering radius.
Another option would be to see how my LJ Moab wheels with 5" BS fit lifted Cherokee, but they have 33" OD x 10.50 width Buckshot's on them.
I found NOS set of 5 of the very limited run of JK 17" Hutchinson Beadlock wheels for the LJ... but they have 6.75" BS and I haven't installed on LJ yet.
Long range plan for LJ is 6.4 Hemi swap & wider stronger axles with 5 on 5 bolt pattern.
Heck I could put the LJR axles in this Cherokee.... humm..
So searching for TJ axles in XJ Cherokee swap.
Old December 5th, 2018, 13:32
smccollamjr smccollamjr is offline
The LJR axles would be a good swap for 31s. 4.10 gears and stronger axles. Front would be a bolt in.
Old December 5th, 2018, 17:31
ocean_jet's Avatar
Other Jeep choices:
I was just goofing around. I'm just jealous it's really an amazing looking XJ.
I am actually putting together a '98 for my daughter who is driving soon as well, also putting it on 31's. It's a 4-door, but the back seat is currently removed. Maybe I should leave it that way for a while...
Old December 6th, 2018, 08:49
Nothing like father / child build for their first Jeep !
I hope with labor invested they will appreciate the vehicle.
What degree leaf spring shims are needed with the ARB CS033RB Old Man Emu Dakar Leaf Springs 3" leaf springs?
What bushings are best for NHV with the ARB springs?
Need get stuff ordered for Christmas... as planning on lifting over holiday school break.
Daughter turns sweet 16 December 23rd.
Old December 6th, 2018, 11:46
Anak's Avatar
Anak Anak is offline
Stranger
Those are what I am running.
If you haven't ordered them yet I recommend ordering them one at a time so they ship separately. Otherwise they beat the daylights out of each other in shipping. See here: https://www.naxja.org/forum/showthread.php?t=1135935
WRT to how much degree of shim, are you running an SYE or not? The geometry is different.
I am running an SYE and I think I am running something along the lines of 6 degree shims, I think...I had used parts on hand that did the job, so take this with a grain of salt. It was more shim than I expected to run.
With regard to bushings, I went with Moog OE style rubber. I think one of the biggest reasons poly is popular is because it is easier to install. I also think doing things the hard way yields a better result in the long run. (Those who know me best can roll their eyes and shake their heads.)
Baby it's cold outside.
Old December 6th, 2018, 12:22
Yes, will be installing SYE, hopefully I can leave TC in while installing.
I've always used Advance Adapters stuff, unless another brand of SYE is preferred.
And new driveshaft. Have always used Tom Woods.
Good idea on ordering springs individually. I've been known to take them apart and powder-coat.
Are the ARB leaf springs ...shackle & main eye bushings same OD as stock?
Old December 6th, 2018, 19:04
Yes!
I used Dayton rubber bushings on my OME 033RA springs.
By the way, I love my OME springs and shocks.
Old December 6th, 2018, 19:32
These are the DPG Offroad spring plate / bump stops that I put on with the OME springs.
Mild build 96 jeep Cherokee Seeker SoCal For Sale 20 February 14th, 2016 08:13
99 Jeep XJ, mild build, $2900 OBO, Indiana Keith_Indy For Sale: Private Party Only. XJ ITEMS ONLY 0 October 23rd, 2013 18:14
01 Cherokee Sport, 53,000 original miles, mild build njjeepthing NAC Classifieds 0 January 26th, 2011 08:34
My Daughters XJ build/Getting Started wade_hack Modified Tech Discussion 122 February 21st, 2010 13:30
My Daughters and my build thread wade_hack NorthWest Chapter 7 January 15th, 2010 08:10
