XJ_Rudolph
- Pleasanton, CA
The rod that the shift yolk is on might be getting jammed in the back of the slip yolk case. Take off the back (not the entire tcase) and see if you can line it up
That's what i figured when we were on the con bcuz It was adjusted pretty perfect
Is it overly sensitive while in higher rpm or at all rpm ranges?
