new issues:
king pins seem sloppy. dude said he just replaced them. I tightened the driver side and that side seems better already. I will check pass side next.
I guess worst case is replace the new king pins, but I think tightening them is going to do it.
AC doesn't come out of upper vents.
PS/hydro doesn't want to bleed. the power steering doesn't work well right now, even with a new pump and royal purple fluid. I probably have air in the lines.
swapped in a high output alternator, new PS pump, brand new water pump, idler pulley and AC compressor. and did a tune up. replaced some missing bolts here and there.
swapped out the trackbar heims and welded up weld washers over the mounts for good measure to prevent any future wallowing .
replaced a bad pitman arm heim too with a RS heim I had lying around. I actually still have like 3 brand new sets of RS 7/8 heims so I am just gonna use them up .
still need to mount new tires and fix tcase linkage among other things.
AC doesn't come out of the top two vents ?
ALso, I noticed the king pins have play in them . jacking up the front and dropping it down you can see the knuckles move. I tightened up the driver side and it seemed to do it. I need to check the pass side .
I might need to replace the king pins. Not sure yet.
new AC compressor
these came
