Boostwerks.com
- Colorado
That is some sexy shit man. The piston slap you have is normal of a lower silicon piston, as long as it goes away once warmed up.
However, I doubt the injectors are the cause of your 3k lean spike. Normally an overworked low imp. peak/hold injector will go full open and it will peg rich before slowly leaning out as the RPMs increase... However, I'm not exactly an expert on chysler ECUs. Also a 23lb injector does sound VERY small for that motor. Are you consistently getting that spike?
