After some error on my part in measuring deck clearance here are my numbers:
Cylinder #; Front; Rear
1; .004
2; .003
3; -.001 (above deck)
4; .0013
5; .0043
6; .0039
So, quench ranges from .043" to .0483"
Yes, my connecting rods aren't the same length. So much for stock connecting rods. But it will do, and my machinist says it is normal for stock rods to be off this much.. I would like to see .004 or .005" across the board though.
At this point I have found the deck clearance and degreed my cam. A few pics from that.
The setup: (18" degree wheel)
How I attached the pointer (water pump bolt, some random brass bushing filled and a piece of hanger)
Dial indicator setup on intake pushrod
Finding TDC 20* before TDC:
Finding TDC 20* after TDC:
That was after I had adjusted the pointer to TDC and used a dial indicator instead of a piston stop.
TDC:
Intake valve open at .050":
Exhaust valve close at .050":
I installed it straight up and that is what it is. Center line worked out to 107*, which is what it is suppose to. I also checked teh valve open and closing timing. The Intake Valve Open was slightly off. I got -5.2* BTDC, when it should have been -4* BTDC. I verified all readings 5 times. I don't think 1.2* off will matter in my application. This is the first time I degree'd a cam. I was actually over thinking it and just confused myself while thinking about it, but once into it it was very easy. Its good to know that the cam reads close to what it should be. BTW, its a Comp Cam 68-231-4
How it sits now:
The only check left I have to do is the valve to piston clearance. I picked some weak springs up at Home Depot to replace the running springs so teh lifter won't compress. I am not expecting any issues, but I might as well verify that sine I have everything. Hopefully that is tomorrow. If I have time I will also put the timing cover on, the main girdle on and the oil pan on.
