triple 4
- Cache Vally Utah
Ok, the swap is done A Cherokee drive train into a Comanchee Sport truck. 4.0,AW4,242, with a custom driveshaft. We fired it up tonight and she ran like a raped ape!! Dispite the coil problem, I took and switched the coil form the cherokee into the MJ and it would turn over but it would not start? So out of a fit of rage I changed the coil and it poped right off, go figure, only in a Jeep! I also took the bench out and put in two bucket seats, the pain was they would not bolt right in, oh no I had to change out the bottom brackets, and put the MJ's brackets on the XJ rails, then it slid right into place with a little help from the BFH. If you have any questions reply back to me, I'm no expert but I will try to help. Triple 4
