blistovmhz
- Vancouver, BC
98xj, 5.3/4l65e, built d30 (blah blah blah), pretty near stock d44 (lunchbox, kj disc conversion - retained e-brake), 4.56 gears.
The 44 has always leaked on me from both axle seals since before the kj disc swap. Finally got around to actually inspecting the seals and mating surface, and sure enough, the shaft is grooved.
I wouldn't normally post about this as there are several obvious options.
1. Speedi-sleeve it. Seems like a lot of work to save a small amount of money when I could instead:
2. New chromoly shafts.
I post though, because it may just be time to look at another axle all together. The 5.3 is making a tonne more power than the 4.0L ever did. While I don't feel it's enough power yet to grenade the 44 shafts, it may be enough to chew up the R&P.
I was going to just say screw it and go to some tonnes, but after working on a few sets over the past year or so, they seem to introduce a few new and exciting problems of their own (ie: pumpkin clearance (still sucks even after a shave), more seal issues and at least 3x more places for stuff to leak from, having to do a tonne of work to get them to fit under the Jeep). Really, at the end of the day, I'm trying to solve a seal issue and a POSSIBLE strength issue that may never actually be an issue, with a 1 tonne axle that is 3x more likely to leak .
Suggestions?
Suggestions?
