- San Juan Ridge, CA
This guy http://chico.craigslist.org/pts/3674423934.html has a D 30 with 5.13 gears. Is this possible?
if its a JK 30.
There's one on Pirate right now but with a Tru-Trac
http://www.pirate4x4.com/forum/axle...hp-dana-30-4-56-trutrack-hd-cover-so-cal.html
Can we assume ZJ? the WJ is too wide ... ZJ grand cherokees have CV shafts. I wouldnt carry them for spares. As for unit bearings, that depends on your brakes. the unit bearing has to match your rotor depth and OD. so just compare the rotors on the setup to yours, if they are the same rotors, then you can probably use the unit bearings. Id recomend googling it if you have any more questions, this topic has been covered in great detail in the past.
these dana 30s wont work:
All low pinion, very narrow:
2000-2001 xj and all non rubicon tj's had lp 30 amd all parts can be swapped.
Shafts are all the same size but brakes and unit bearings differ
I know you know. You know I know you know. Just wanted to cut out confusion, you know
