- San Juan Ridge, CA
i bet rob would consider welding coil buckets back on, and youll need a new stock trackbar mount as well, maybe he would do that. he is still using the stock link location for the UCAS, so the only issue with the 3 link is the trackbar being raised. if you got his steering and trackbar then you'd be setup pretty good.
welding stock coil buckets back on, maybe LCA mounts, thats easy to do. shock mounts are easy as hell, double shear or studs, just weld em on.
youll gain the strength of the cryo r/p and the truss, which is nice, and the better brakes arent to bad. just some food for thought.
Thanks Jon! I asked him if he couold get it back to stock so we will see what he says. I dont need to locker and someone already asked for it so hopfully we can make a deal.
Thanks again for the help.
