Boostwerks.com
- Colorado
True Trac owners... you may not have noticed it yet, but your diff may be loosing it's ability to transfer torque due to one design flaw. The primary worm gears are wearing agains't the housing ends, slowly wearing a groove into them as a result. As this wear occurs, the center bevel washers drasticly loose their preload and you eventually end up with a normal open diff. :tear:
I have seen a couple with the same problem and intend to "propose" a fix to Eaton. This write up covers this fix for those of you who would like to do this as well. I had picked up a used True Trac a while back with the intention of rebuilding it to test this potential fix. While this may seem like a lot of work to improve on a limited slip, the True Trac and other helical gear LSD's do work great and offer a stiffer housings than compareable clutch type LSD's. Also the center cam bearing and bevel washer design work great, will last a very long time, and can offer tuneable amounts of load transfer. By changing the thickness of the bevel washers or adding shims to the cam bearings you can change the amount of preload. As you'll see later in the write up, I added two .008" stainless shims to increase torque transfer.
Parts List (McMaster Carr):
5909K42 - Bearing Cage (2 needed)
5909K55 - Bearing Washer (4 needed)
98126A433 - .008" Stainless shims (up to you)
6 - 1/2-13x1.25" Grade 8 flange bolts
Loctite 243 (oil resistant)
Some moly lube or grease for reassembly
Tear Down:
I started with disassembling the diff by unbolting one side of the case, and then removing the components making sure to note the correct orientation to help reassembly. Once the inner components are removed, the other side of the case can be unbolted and the remaining worm gears removed. All parts were thrown in a parts washer for a couple hours and then inspected for wear.
worm gears:
one of the two primary gears:
Empty case:
One of the cam bearings that presses against the primary gear
The two bevel washers at the center of the diff (note the orientation):
This is what the assembly looks like inside an assembled diff:
One of the case ends. You can easily see the area where the primary gears is starting to wear into the housing.
A close up of the wear. Notice how much material has been removed simply by the operation of the diff.
Tear Down:
worm gears:
Empty case:
