Window Frame Rusting
88XJSport
Michigan
My right side window frame looks like its rusting. Any way to fix this without replacing the whole frame?
The hole window just pops out, Have you seen if there is rust, If i had that same problem i would pull the whole window becasue there is probley more rust then what you can see. If you havent pulled your carpet up you might want to check because i bet you have some leaks. Got to love the cherokee :)
It seems as though its just the frame that is rusting. So do I just remove the trim from the inside and push the window out? Then Im guessing I can replace the frame as a whole when the window comes out??
