who's ready and who's not?
Both axles are trussed and shaved!
I will paint tomorrow, and Mon. my man will install the gears.
A UPS truck is headed my way and soon I will have more goodies to play with!
You got new drums comin' for them HD brakes? :D
Les
That's bullshit, man.
Learn to do your own fcking gears.
What in Hell is this place becomming?
Time was, each of the "Big 10" of NAXJA could do gears at the drop of a hat.
I'll bet only one of the "Big Three" can even do gears.
Hmm, I hadn't thought of that. On one hand, I think I may have acted hastily by putting a mini-spool in my MJ; but on the other hand, you don't know until you try and they certainly are easy enough to swap.
You didn't.....
seanR said:
I would just weld the front randy, I hear that works real well!
Okie, want to teach me to set up gears?
Absotively.
Bring them with you to WF and I'll tell you how.
93XJMan said:
Hey I got a couple friends that drive TJs and YJs they are wondering if they can join you guys?
bylaws said:
e. Members who choose to bring Guests on an Event are solely responsible for the safety and the behavior of those Guests. Should the Trail Master or any attending Director determine that any Guest is posing a risk to safety, or simply to the enjoyment of the Event itself, that Guest may be asked to leave via host Member escort provided it is deemed safe to do so by the attending ranking Director and/or Trail Master.
f. Each Member may invite not more than one (1) guest vehicle to attend each Event.
g. All participants shall be defined as an Attendee, either Member or Guest. At no time will any other vehicle be allowed to join any Event. The Trail Master and/or attending Director shall enforce this policy without exception.
Technically, no, unless they are "sponsored" by another NAXJA member. This has been arranged in the past as long as a member is willing to do so.
Les
Okie Terry said:
You didn't.....
What's wrong with it? 33's on a D44 under a lightweight MJ, I don't see a problem. Didn't you run a welded 8.25?
He was talking about the front axle of his Jeep.
I thought you were too.
I guess I thought you were going to run a mini spool in the front of your MJ.
Nevermind.
Nevermind.
Sean was, but I was carrying on a sub-conversation with Randy about the broken Lockrite in his rear end that he replaced with an Aussie. I suggested a mini-spool and then revealed that I recently installed one. I'd never advocate a spooled front, regardless of methodology.
sorry, guess it wasn't clear....that lockright was in my front d30.
What caused it to fail? im considering one for my rear end - and cant afford to have my rear wheel drive go out if there is a problem...
anything that can be avoided...
X 2
Need to decide what to put in the 8.8.
I've got one in my D30 now.
IntrepidXJ said:
i got a lockright in the rear as well, and have not had any issues with it.
my front end has been making extra clicking noises for a little while....if i weren't so lazy and had checked it sooner, i probably could have repaired it with a new spring kit.
the price is enticing - especialy as there is no Aussie for the Ford 9 yet...
would you reccomend it?
